WC, WD, and WD45 questions
Lance Weber
12-21-2003 12:53:33
Curious about a few things. What was the weight and horsepower of each of the above listed tractors(with gasoline engines)? Also, did the WC come with wide front? Pretty rare? Thanks, Lance
Billy Shelton
12-24-2003 07:56:59
 Re: WC, WD, and WD45 questions in reply to Lance Weber, 12-21-2003 12:53:33
Question - Any suggestions on getting the pin out to replace brake linings?
Need help! Any suggestions welcome.
Thanks
wdTom
12-24-2003 18:49:54
 Re: Re: WC, WD, and WD45 questions in reply to Billy Shelton, 12-24-2003 07:56:59
If this is the pin in a wd or wd45 go to the archives, there is a LOT on this little problem.
John (C-IL)
12-21-2003 15:50:44
From Terry Deans book: WC 3300# on rubber, 24.16 DB/29.93PTO; WD3388# 30.23DB/34.63PTO; WD45 4465#, 37.84DB/43.21PTO
John (AZ)
12-22-2003 08:40:45
 Re: Re: WC, WD, and WD45 questions in reply to John (C-IL), 12-21-2003 15:50:44
I'm curious why the HP difference between the WC and WD? They were the same engine.
John (C-IL)
12-22-2003 12:32:27
 Re: Re: Re: WC, WD, and WD45 questions in reply to John (AZ), 12-22-2003 08:40:45
They are the same basic engine, but the rpm's were upped and the govenor changed, they also had a different carburator to get more horsepower. In reality the same W engine went all the way into the 70s, AC just kept turning up the wick a little.
Aaron SEIA
12-21-2003 15:16:27
Not sure on the weights and HP, but the WC did come with a wide front, and yes, it was pretty rare.
Aaron SEIA
