What kind of oil to use?
Bert E. Singlet
12-19-2003 14:50:43
A friend of mine just got him a 1940 Allis Chalmers CA. He redone the motor but the hydraulic system has water in it and he doesn't know what kind of oil to use in it.
Max(ia)
12-21-2003 07:33:04
 Re: What kind of oil to use? in reply to Bert E. Singleton, 12-19-2003 14:50:43
I use 20wt non detergent in my 51 CA, works just fine.
Chris
12-19-2003 16:37:28
Universal Tractor Fluid works just fine if the seals are not leaky. NAPA and Walmart carry it. If the seals weep you can go to a gear oil but the hydraulics get mighty sluggish in cold weather. BTW- the CA was not built until 1949-50.It is either a C or newer than you think. Post the serial number and someone will tell you what it is.
steve
12-19-2003 18:10:13
 Re: Re: What kind of oil to use? in reply to Chris, 12-19-2003 16:37:28
the transmission, differential and PTO housing share the same oil. there are 3 of a 1/2 inch pipe plug on the bottom. pull all three. one fill next to your left foot on the transmission case. yes- 20wt unniversal hydraulic fluid. dont be suprised if the new oil looks a liitle "wet" after hours use. hard to get all the old stuff out. might want to change a second time after a couple days if you can afford another $10. takes about 8 quarts. if you have a 4 speed it is CA, if it is a 3 speed it is a C.
