Help finding axle shims
Dave Wi.
12-17-2003 15:05:49
I know I need em,just dont know where to get em. WD45 has side slop in left rear.
L Hud
12-18-2003 08:07:05
 Re: Help finding axle shims in reply to Dave Wi., 12-17-2003 15:05:49
If the short axle has movement, you should be taking shims out and not putting them in. Underneath the bolt and washer that holds the axle in should be shims. To tighten the bearing, you should remove shims,not put them in. If you have no shims and a lot of movement, it's time to put in some new bearings. Hope this helps.
Dave Wi.
12-18-2003 08:52:48
 Re: Re: Help finding axle shims in reply to L Hud, 12-18-2003 08:07:05
Thankyou, now I gotta back and look it over closer,your proly right I may need bearings.
