Power Director
HoyBoy
12-15-2003 02:51:12
I've been trying to figure out how a power director works by peicing things together from the archives. If I'm getting it right, the shifting from high or low range to the neutral position would work great when baling hay if you came to an almost clog the baler situation. Just move the power director lever to neutral until the baler works through the hay, and then move the power director back to low range and resume forward motion. If this is how it is used, it seems that it would save on the clutch and the operator's left leg. Am I getting this right?
jim ball
12-17-2003 07:17:46
 Re: Power Director in reply to HoyBoy, 12-15-2003 02:51:12
i have ac 200 with power director giving 4 x 2
gears. it is true that shifting to neutral with the power director with your hand allows the tractor to stop & live pto for the hi & lo range.
however, if you shift gears with your foot clutch
the pto stops. this is often a nuisance & a poor
design. unlike, multipower or torque amplifiers,
when in either range ( hi or low) one will not
free wheel. this feature i like.
SamH
12-15-2003 04:23:02
That's one of the purposes it serves. The best thing about the director is that it gives you the option of totally stopping forward motion or shifting up or down on the go. It's great for plowing, working through thick/thin hay with the baler, heavy/light grass with the bush hog, or anything where conditions vary. As you say, it saves your left leg and also doesn't give much trouble, since it runs in oil.
Tom
12-15-2003 03:52:51
That is exactly what the power director is used for plus shifting from low to high range. It was also used on the roto baler to stop forward motion to tie and eject the bale. Since it runs in oil there is little wear from repeated use.
