d17 wont start
dw
12-14-2003 12:29:11
last run this tractor about 2 monthes ago, all of the gas leaked out of the tank, when i put gas
back in, it wouldnt start, ive got gas in the carb but the plugs are dry. ive cleaned out the carb
and air filter but no luck. any help?
dw
12-15-2003 07:46:58
 Re: d17 wont start in reply to dw, 12-14-2003 12:29:11
took carb apart everything but the idle jet
i believe ' the one thats in the trouht' could this be the problem? thank for the help.
ed
12-15-2003 11:55:55
 Re: Re: d17 wont start in reply to dw, 12-15-2003 07:46:58
any of those needle ports or passages, make sure they are all clean. Nice thing about a tractor carb, they are pretty simple, not like a motorcycle or snowmobile! My problem was thata little no nothing brass port I mentioned befor, purring liike a kitten now!
Hope it helps.
ed
ed
12-14-2003 16:44:17
I recently had similar problem, turned out the "jet" located at the bottom of the fuel bowel of the carb was plugged. Brass "port", unscrewed it and blew it out solved the problem.
steve
12-14-2003 15:19:49
if carb has gas, but cant get into motor, sould like a jet might be plugged. how about pulling the plugs, put 2 spoon fulls of gas in each cylinder and reinstall the plugs. should fire and run for a few seconds. if it dies and wont restart, carb is not feeding gas.---dont have a vacuum leak on the carb to manifold gasket, or manifold to head gasket do you???---alos, pull and plug and stick in the plug wire. lay it on the bare part of block and hit the starter, does it spark??- good to chek point and corrosion.
