AC WD or WD45
Roger
12-13-2003 13:06:32
I have an AC tractor and I want to know if it an WD or WD45. I know the tractor serial # is WD112198.Thanks!
AZ Jack
12-15-2003 18:47:28
 Re: AC WD or WD45 in reply to Roger, 12-13-2003 13:06:32
According to SN it looks like a 1952 WD to me.
carl from nebraska
12-15-2003 11:11:43
I,m looking at an AC WD45 for cheap. Been in trees 4to5 years. Put a big pipe wrench to the front hand-crank shaft but unable to turn motor. Got a suggestion to further check for stuck engine? Maybe next step to breaking it loose? She looks fine so am anxious to free her from this spell. Stuck in Nebraska.
john
12-14-2003 19:55:22
Allis Chalmers Model WD-45 [ Return to Models] [ Return to Main List]
Year Starting Serial Number 1953 146607 1954 160386 1955 190993 1956 217992 1957 230295
The Serial Number is located on top of left differential brake housing
john
12-14-2003 19:53:09
Allis Chalmers Model WD [ Return to Models] [ Return to Main List]
Year Starting Serial Number 1948 7 1949 9280 1950 35471 1951 72356 1952 105216 1953 131273
jd guy
12-14-2003 11:12:33
wd has a straight gearshift lever...wd45 shifter will be curved...easiest way to tell..
John (C-IL)
12-14-2003 11:53:16
 Re: Re: AC WD or WD45 in reply to jd guy, 12-14-2003 11:12:33
Some of the late WD's beginning with serial number 127008 in 1952 had the curved shifter. The only definitve way to determine the model designation is the serial number.
It's a WD
12-13-2003 13:39:37
WD's end with serial number 146606
