Brake Band removal on an unstyled WC
Wayne
12-11-2003 14:23:23
Woodruff key is giving me a problem. It pretty well stuck in the slot of the brake band. The inboard sleeve move OK. The other side came out very easy. This side has no lining so I need to get it out. I have heated up the center part several time. Got it pretty hot. I'm open to any ideas.
Thanks,
Wayne
Joe M
12-12-2003 18:52:11
 Re: Brake Band removal on an unstyled WC in reply to Wayne, 12-11-2003 14:23:23
Wayne, I would just start striking the end if the shaft with a hammer.If you have the key lined up in the band right, the shaft will bring
out the key and the inside bushing with it as it comes. I would suggest you put something between the band and the housing to keep it from twisting before you start with the hammer.
