AC 190 (2800) engine problem
simon w
12-10-2003 13:37:59
Piston #1 is broken in two. Of course it is the thrust bearings that are worn allowing the crank to move horizontally. There is a fair mount of metal in the sump but the engine runs on 5 cyls OK. My question is is there any way of replacing the thrust bearings without a complete engine rebuild. Does any body have a good 2800 or 2900 for sale?
Glum
Joe(TX)
12-11-2003 10:06:53
 Re: AC 190 (2800) engine problem in reply to simon w, 12-10-2003 13:37:59
You can replace the main bearings as long as the thrust surfaces on the crank are ok. More than likely they are worn out of tolerance.
