Hydraulics on AC D-17 need some help
Vern
12-09-2003 19:38:31
Working on a AC D-17 and the hydraulic lift was working but now it will not come down. Could someone tell me how to fix it? Thanks
Pon
12-12-2003 21:06:47
 Re: Hydraulics on AC D-17 need some help in reply to Vern, 12-09-2003 19:38:31
Mr. Vern, you didn't say whether this is with the tractor running or not, or whether the hydraulic outlet or the lift arms, but it really doesn't matter that much. The linkage that goes down from the lever on the steering wheel activates a valve inside the pump to release the pressure. Just right off the bat you'll want to check that linkage to be sure it's working down near the pump. Also, check how the lever feels, does it feel as if it's contacting anything when you go down with it? If you see nothing obvious on the outside you may need to drop the bottom off and check inside the housing. God Bless.
