D17 Clutch
Don Holden
12-09-2003 13:28:37
I am consdering replacing the clutch disc on the 17 before spring field work starts. I am told that there are 2 different discs available for the tractor. One is heavy duty and is considerably higher priced. My question is: For normal field work, such as plowing and other normal field work should I use the regular or go to the heavy duty? If I go to the heavier duty disc are there any changes recommended for the current factory pressure plate?
Thanks for you advice
Don
D-17 Puller
12-10-2003 18:39:36
 Re: D17 Clutch in reply to Don Holden, 12-09-2003 13:28:37
For normal farming conditions, the regular clutch will be fine. The heavy clutch has 6 small seperate pads evenly spaced on the disc. The heavy disc is less likely to slip under extreme conditions(tractor pulling),but wear out quicker due to less surface area.
