wd 45 oil pan gaskets
Pete Churilla
12-08-2003 17:09:31
I am rebuilding a wd45 and currently installing the oil pan,there are two small gaskets with a radius cut and a slot cut,I do not know where they go,they come in the oil pan kit,if any one can help I would appreciate since I am at a standstill.In my manual there is no drawing showing thses gaskets. Thanks Pete
wdTom
12-08-2003 17:56:29
 Re: wd 45 oil pan gaskets in reply to Pete Churilla, 12-08-2003 17:09:31
They go around the rear bearing cap, if I remember between the cap and the upper seal holder. My manual says "Use the key shaped gaskets between the bearing cap and block". But I think it means upper seal housing.
