Todd in NC
12-08-2003 08:20:20
Re: New A-C CA owner questions in reply to denton, 12-07-2003 18:32:39
Denton, congradulations on getting your CA. The other replies are right, you need to get the manuals for it. But since you asked, I'll do my best to answer. 1, I use SAE30 ND in mine. You fill the transmission, differential and hydraulic system all at the same time and at the same place. On the left side of the trans. theres a dip stick, put it in & check it there. You have to have the PTO in gear to work the lift. 2, Good luck on finding hand clutches. Valu- bilt has them, but there used not rebuilt or remaned. They just take them out of a junked tractor and send it to you. 3, 10-24 4, The generator was 6v positive ground. I beleive Delco. If your system has been rigged up like you said, I would suggest you convert it to a 12v negitive ground set up using a one wire alternator. It's quicker cheaper and easier. 5, I don't see any reason that you couldn't swap a narrow front for a wide front, but I'm not 100% certain. 6, I don't know of any web site to get any better information from. I know what you mean though. I come here to get info. myself, but if you don't have a B, WD, or WD-45 it's like you don't exist. If you think that's not true, just look at the other questions on this board. They'd rather give marital advise than help someone get their tractor going. I have two CAs, one wide the other narrow. These are my utility tractors, and see work on a regular basis. My wide front needs a hand clutch now. There is one on e-bay at this time, but how do you know if it's good or not. That's the delema I'm in. I'm sorry, I didn't mean to get started venting. I hope that I've been some help to you. That's what this board is for. Good luck, Todd.
