allis D-17 need some help
BRYAN -IN TEXAS
12-07-2003 18:15:07
I have a 1967-D17 Lpg series 4. I was told that a ac gleaner c-2 engine a262 will bolt in with little problem,can any body please help me out with some information about this,and i would like to change to gas& not LPG.I was thinking a hood&gas tank off a D-19 might work. Would like any ideals or information. thanks for the help
DG
12-18-2003 20:40:36
 Re: allis D-17 need some help in reply to BRYAN -IN TEXAS, 12-07-2003 18:15:07
Would you be interested in selling the LPG conversion complete with hoods etc. if you convert yours to gas? Please respond.
Bob D 19
12-08-2003 10:21:10
Hi, I believe your d17 has a 4 cyclinder, the 262 is a six and that is what is in the d19,the hoods are longer and taller, this means you would have to incorporate basically all of the sheet metal off of a 19 and the gas tank is much larger on the 19,not to mention frame rails,steering rod and throttle linkage.We have a 19 and a 17 seris 4 even though they look similar they are very diffrent. Your best bet would be to find an older 17 to get your parts from and stick with a four cyclinder. just my 2 cents. Bob
Eldon (WA)
12-08-2003 19:20:59
 Re: Re: allis D-17 need some help in reply to Bob D 19, 12-08-2003 10:21:10
You can use the sheetmetal, rails, steering and linkage parts off a D17 diesel as they use the same 262 6 cyl engine block.
bryan
12-08-2003 17:50:01
thanks bob for your two cents,it gives me some things to think about.
