ALLIS 160 TRANS...PARTS
CHRIS
12-07-2003 10:55:24
WHAT ARE THE MOST COMMON PROMBLEMS WITH THE 160 TRANS... ARE THERE ANY COMMON PROMBLEMS WITH THE 3 CYLINDER ENGINES? WHERE CAN I FIND PARTS? THANKS
cody
12-08-2003 15:42:58
 Re: ALLIS 160 TRANS...PARTS in reply to CHRIS, 12-07-2003 10:55:24
Chris, I just had my clutches and pressure plate re-lined and machined by a place in Memphis, Tn. The price for rebuilding the pressure plate and both the clutches, a new throw-out bearing and a new pilot bearing was $350. The place is called Laycook Products their # is 1-800-238-7190 or (901)523-1418 they did an excellent job for me.
Chris(WA)
12-07-2003 13:35:16
Mine liked to stick in gear (3-4)till I changed oil. Easy to get water in the trans if the shift boot is worn. I have heard clutch parts are VERY hard to get. The Perkins is a dream! Run good and start excellent. A bit underpowered if anything. Agco has a fair parts supply for most things. Concidering this is a tractor that they imported less than 10,000 of over 30 years ago I think they are champs!
Chris
12-07-2003 14:39:00
 Re: Re: ALLIS 160 TRANS...PARTS in reply to Chris(WA), 12-07-2003 13:35:16
CHRIS WA: ARE THE CLUTCH DISC HARD TO FIND? THE LOWER 3 PT ARMS ARE MISSING. DO YOU NO WHERE I CAN FIND THEM?
Chris(WA)
12-07-2003 16:43:47
 Re: Re: Re: ALLIS 160 TRANS...PARTS in reply to Chris, 12-07-2003 14:39:00
I would expect that the discs(2) could be relined if the disc is salvagable.P/plates and T/O bearings are suposed to be the buggers. A pair of arms I do not have a line on. One of the wrecking yards should be of help. Or you can buy new ends and build your own.
