WD45 with clutch problem
Rick Keck
12-06-2003 20:55:51
Tractor sat for about 12 months, prior to that clutch was working fine. Now can't get clutch to disengage. I�ve adjusted all the play from the linkage and tried adjusting the 3 release levers and I can see the pressure plate moving when the clutch pedal is pressed, but still can�t get the clutch to disengage. Any suggestions will be appreciated.
RAY DIEMERT
12-06-2003 23:18:22
 Re: WD45 with clutch problem in reply to Rick Keck, 12-06-2003 20:55:51
clutch plate is stuck to fly wheel.
try hooking tractor to a solid belt pulley load while depressing clutch pedal repeating in and out
Matt
12-07-2003 18:27:25
 Re: Re: WD45 with clutch problem in reply to RAY DIEMERT, 12-06-2003 23:18:22
I have also had luck driving the tractor around until everything is good and warmed up, then while driving along press in the clutch pettle and start braking, (you may have to brake hard and possibly stall out the tractor) some times this breaks the disc away from the flywheel. Good luck.
wdTom
12-08-2003 18:09:07
 Re: Re: Re: WD45 with clutch problem in reply to Matt, 12-07-2003 18:27:25
Stall a 45???
