ac 160 hydraulic problems
cody
12-06-2003 15:23:06
My 160 will barely pick up a 5ft bush hog. It will not keep it held up at all. It has plenty of new fluid,and the filters are clean. Any suggestions? Also my control levers seem to work backwards, the manual says the inside lever is for traction boost, but it is the one that works my three point arms. The outside lever seems to do nothing.
Chris
12-07-2003 06:30:09
 Re: ac 160 hydraulic problems in reply to cody, 12-06-2003 15:23:06
My 160's control work the same as yours Cody. I have to have the T/B lever all the way up to get it to lift up and all the way down to get it to drop down. Can't help on the staying up part though. Mine fails to lift occasionall after sitting . Have to bleed the hydraulic pump of air and she takes right off.
Mike
12-06-2003 20:00:55
The inside lever is the traction boost.It needs to be pushed all the way down when using non ground engaging implements.The T.B. lever has two stops at the bottom. The first stop is for slow lowering of implement,mainly used when plowing but can be used for any implement.The very bottom stop is fast lower, using it lowers the implement much faster.If the T.B. lever is not all the way down(first or second stop) the hyd. system will not work properly when using the position lever(outer lever).Agco still sells operators,parts and service manuals for this tractor.About 70.00 for all 3 if memory serves.
Mike
