Electronic ignition for a WD-45?
Greg Cox
12-05-2003 04:04:33
Does anyone know of an electronic ignition conversion for a 45? I got to thinking about this on the road last night and thought it would be a nice upgrade for my orange mule.
JS in IL
12-05-2003 20:03:43
 Re: Electronic ignition for a WD-45? in reply to Greg Cox, 12-05-2003 04:04:33
I used a pertronix 12 volt electronic ignition kit in my wd-45 and it so much better than points. I went the extra step and added a msd 6a ignition amplifier and heavy plug wires and blaster2 coil. Sucker starts and runs smooth in 2 Degree weather with about half a spin of the crank.
Ron
12-05-2003 09:21:26
' If yours is like mine, it really won't "spin over" with 6 volts...!! I put 12 Volt + ground on mine, and it is Great..!! had to change the lite bulbs, and went to an alternator ( old Ford ).. Now, I can jump-start the rest of them...!!
Doug in OR
12-05-2003 06:47:33
I'm sure Pertronix has a kit that will fit. You can do a search for "pertronix" using the search button on your browser. There is also one available through this web page, but I can't find the location here.
Most kits require 12 volts, negative ground. Pertronix might have one that doesn't. If you haven't converted to 12/negative, you may need to do so first.
Dave Grubb
12-05-2003 06:45:28
Seek out the Geneesee Products folks on this site and purchase their kit. I put one of their kits in my WD45 and have been well satisfied with it.
RB/CT
12-05-2003 18:32:12
 Re: Re: Electronic ignition for a WD-45? in reply to Dave Grubb, 12-05-2003 06:45:28
Thought I just saw Petronix ignition in Eastwood Automotives catalog, and they had them for 12 and six volt.
