W D engine problem
buford
12-04-2003 19:26:32
W D 1948 w/ dist. starts good runs at idle but when under load it sputters and dies good spark,compression good, starts back, does it all over again, could I have water problem ?I drained bulb at tank, gas seems ok what do you think? Thanks, Buford
buford
12-13-2003 16:51:23
 Re: W D engine problem in reply to buford, 12-04-2003 19:26:32
thanks guys I have found some water in carb. put in new points kit in carb. runs like it should . thanks for all your input. Buford
wdTom
12-05-2003 17:27:17
I know you say you drained the "bulb" at tank, but have yoy taken the plug out of the bottom of the carb and drained gas from it, a lot, maybe a pint or more to see if the flow to the carb is steady and lasting? Tank or lines could have partial blockage.
Ron
12-05-2003 09:15:29
If it idles, and WAS running good--and you are pretty sure the carb is ok, I would suspect weak spark...maybe old sparkplugs...??? Condenser....?? A piece of dirt in the power needle will lean out above-idle transition, too..
Dave Grubb
12-05-2003 06:51:33
You could add some gas line anti freeze to the gas to get rid of any water if you feel that may be a problem. I use the stuff called ISO in the red plastic bottle. It is basically isopropyl alchohol. The other types use methanol which is corrosive if left in the tank for long. Did you try to adjust the main jet needle valve a little one way or the other to see if it helps?
Brandon
12-05-2003 04:15:04
I'd say check dist. timing or carb.
old
12-04-2003 20:38:17
I'd say you need to clean the carb maybe rebuild
TimC
12-04-2003 19:57:48
Moisture in the dist?
