Crank start repair parts for a B or C
Chris (OR)
12-04-2003 07:49:03
In the process of restoring my '39 B I wanted to repair the thru-holes for the starter crank. I ended up having a number of plates laser cut out of 1/8" thick steel plate. To meet the min. order I had to get extras made. Thus I am offering three plates I have extra. They are the exact size and shape to replace the ones on the radiator support. You take a cold chisel and about two good raps takes off the old ones that are just spot welded. I also used one to clean up the front radiator grill surround. See photos at the link below. I am just offering these to help some one else with a B (or a C, may fit others, check your own applications). This is for a total of three plates, enough to do the support and the front sheet metal.
Thanks
Chris Horn
Scappoose Oregon
