WD45 axel seal
David (FL)
12-02-2003 18:19:42
I am trying to remove the axel to replace the seal but can't get to the snap ring on the outside of the gear. I have shown this to several local mechanic and were all stumped so can someone out there HELP!
Brian G. NY
12-03-2003 19:17:38
 Re: WD45 axel seal in reply to David (FL), 12-02-2003 18:19:42
Did they look at the actual equipment or the diagram in the manual? I replaced a seal on my WD a couple of years ago. If I remember correctly the outer snap ring is an "internal" type; in the housing, not on the axle shaft. It does not retain the axle, but instead provides a backup surface for the outer bearing cone and therefor, does not need to be removed to remove the axle. So.....the axle comes out after you remove the inner snap ring and the retaining bolt on the end of the axle. Be sure to block up the bull gear so it doesn't come crashing to the floor when you pull the axle.
