WD WD45 Pistons
Rob
12-02-2003 16:16:28
Could anyone tell me the difference in the WD pistons, and the ones used in the WD45. Also what was the M&W pistons like for the 45. If anyone has pictures that would show the difference, I would appreciate it. Thanks, Rob
Kent of SW MO
12-03-2003 09:02:45
 Re: WD WD45 Pistons in reply to Rob, 12-02-2003 16:16:28
Piston pin in a WD-45 piston is .250 higher than a WD. Measuring from the top of the piston to the center line of the piston pin is the compression heighth of the piston. This distance is less on a WD-45 than on a WD. Put WD pistons in a WD-45 will raise the compression. Some much that 12 volts on a 6 volt starter will not crank it.
JMS/MN
12-05-2003 14:25:51
 Re: Re: WD WD45 Pistons in reply to Kent of SW MO, 12-03-2003 09:02:45
Original pistons in a WD were a flat top, WD45 Power Crater pistons had a concave top. Also, wasn't the diameter increased in the WD45? Can't remember without checking the spec book.
Steve
12-06-2003 08:15:47
 Re: Re: Re: WD WD45 Pistons in reply to JMS/MN, 12-05-2003 14:25:51
If you put WD pistons in a WD45 your not going to start it. you can drag it around the driveway with your truck trying until you break the crank or tear the clutch up if you want.
Jason
12-09-2003 10:51:30
 Re: Re: Re: Re: WD WD45 Pistons in reply to Steve, 12-06-2003 08:15:47
Steve you are wrong I have a WD-45 crank in my WD and it has the WD pistons in it all I done was rebuilt starter and starts fine.Also rebuilt motor at same time and I havent any trouble.JASON
Steve
12-20-2003 04:25:33
 Re: Re: Re: Re: Re: WD WD45 Pistons in reply to Jason, 12-09-2003 10:51:30
Sorry you are right Jason I was bacwards you can't put WD45 pistons in a WD.
