D-17 Hydraulics
kim
11-30-2003 15:39:41
I have a 1958 D-17. I can only get 1500 psi out of the hydraulic system. I have rebuilt the lift cylinder and added shims to the pump but it doesn't help. Does the pump need to be rebuilt? Thanks for any help.
Pon
11-30-2003 21:42:38
 Re: D-17 Hydraulics in reply to kim, 11-30-2003 15:39:41
Kim, that's poor pressure as you know on a system that should pump 3,500 to 3,700. Be sure it has plenty of oil and that it's non foaming regular 20 weight motor oil. You've probably already checked that. Also, is there a knocking sound in the pump or a jerking motion with what pressure you do get? That might indicate that all four plungers are not pumping in the pump. Also, when you raise the lift lever does it sound like it's pumping up then you hear a clunk after which it ceases to try? When it's working right there's a definite clunk at the end of the lift cycle. If it is "clunking" at that poor pressure then the unloader valve is actuating too quickly. If it doesn't clunk and keeps trying then the pump is not able to get up enough pressure to activate the unloader valve which might mean all the plungers are not pumping. It does have what they call an "unloading valve" but not a check valve as such. The unloading valve is actuated when either the pump has done all it can to lift something or a cylinder has reached its end of travel. But that valve is an integral part of and inside the pump itself inside the tractor. If it comes down to it getting the pump out, it's no big deal with someone who is familiar with it. Getting parts for it, like springs, pistons, valves etc., might be another matter now. Sometimes a spring will be broken on one of the plungers and cause that plunger to not return for a stroke and so it doesn't pump. Let me know what it's sounding like, what the oil looks like, water, milky or whatever. Then be sure it's got enough of the right type. Holler back if you get a chance and I'll try to help. Someone familiar with it can have the pump out, overhauled and back in in just a few hours. God Bless.
old
11-30-2003 16:08:55
There should be a relief valve in the system that may need turned up /repaired, that is what is probably limiting your preasure. Sorry I can't tell you where it is but I know it has to be there
