D-17 Baler
HoyBoy
11-30-2003 05:30:40
I want a tractor to run a PTO baler and pull a wagon in tow to put the bales right up on the wagon. The area I'll be working is rolling hills, nothing steep. My question is, would a D-17 series three be a good choice? I found one for sale and 54 H.P. and power steering made me think it would work out great. What do you think?
What's the difference in the series 3,4 etc?
HoyBoy
old
11-30-2003 10:44:20
 Re: D-17 Baler in reply to HoyBoy, 11-30-2003 05:30:40
With a square baler it will do just fine, Its really more tractor then you need. When I did square baleing I used an Oliver 77 which is 38HP so a D17 will just play with that. By the way I pulled a JD-14T baler and a wagon also, the baler had a kicker on it also. Hope this helps
Barry Whalen
12-01-2003 16:50:22
 Re: Re: D-17 Baler in reply to old, 11-30-2003 10:44:20
The D-17 is an excellent tractor for baling as far as I'm concerned. The hi/lo hand clutch is really nice when you hit heavy hay. It can be shoved into lo without stopping. I have loaded alot of hay on a wagon pulled by a series III.
