If there are no mechanical failures (broken crankshaft, rods) and everything moves like it is working dump a few ounces of motor oil in each cylinder. If you want to build compression the oil will help seal the leaky rings. I bought a �dry� car engine like that once. We had fuel & spark but no fire. When I approached the guy I had bought it from about our difficulty in trying to get it to run he said, �Dump a Quart of Oil down the M()!%#%*#^+KER .� I couldn�t believe what I had just been told�engines burn gasoline, not oil. I said, �What� He repeated,� �Dump a Quart of Oil down the M()!%#%*#^+KER .� I needed an explanation, and eventually I understood�. I was to take a one-quart container of regular crankcase oil and slowly pour it into the carburetor with the throttle partly open while cranking the engine with the starter. Surprise, doing so increased the compression from the additional sealing effect of the oil and the engine started long before I�d finished pouring the entire quart into the carburetor. When the oil smoke had cleared we had a smooth running engine! What had happened is the engine had become �dry� from sitting such a long time. When we wanted to start it we primed it by dumping gasoline down the carburetor and that washed what little oil was on the cylinder walls away. Engines depend on oil for its sealing effect as well as cooling and lubrication. I went back to the guy who gave me the advice and told him, �The M()!%#%*#^+KER� started!� He knew it would. That was the last time that engine ever gave us any compression problems because after it had been run awhile the normal amounts of oil inside the engine sealed the cylinders.
