WD 45 transmission service
chuck
11-27-2003 18:03:41
I had water in the transmission so I drained by removing the front two plugs and refilled but when I start the tractor the fluid takes on a milky appearance like I am not getting all of the watery fluid out. Do I need to remove another plug?
Matt
11-27-2003 19:00:34
 Re: WD 45 transmission service in reply to chuck, 11-27-2003 18:03:41
When you drain the transmission you need to remove the plug on the bottom of the p.t.o. The p.t.o. holds about 1 quart of oil in it. You also should drain the differential becouse the oil flows from the tranny to the diff. Hope this helps. I am not shure if you need to drain the torque tube or not, I guess I probably would if the tranny got watter in it the torque tube quite possibly could have to.
old
11-27-2003 18:36:27
Well if I'm reading it right you need to drain the toeque tube,tranny and differ. But I'm sure for sure thats what I just read in my manual
Brian G. NY
11-27-2003 18:50:22
 Re: Re: WD 45 transmission service in reply to old, 11-27-2003 18:36:27
Yep, you need to remove each of the 3 plugs at the bottom of the PTO unit, the tranny and the differential. It will take about 17 Quarts of 90 Wt gear oil to refill your tractor. When you refill, you must fill utilizing BOTH of the two pipe plugs on the LH side of the tractor; one ahead of and one behind the clutch lockout latch.
Nate in IL
11-28-2003 15:12:12
 Re: Re: Re: WD 45 transmission service in reply to Brian G. NY, 11-27-2003 18:50:22
Guys- I don't think 90W is right. My service manual says 20W non-detergent.
wdTom
11-28-2003 18:03:47
 Re: Re: Re: Re: WD 45 transmission service in reply to Nate in IL, 11-28-2003 15:12:12
The plug in the transmission is in the sheetmetal plate bolted to the bottom of the transmission.
I don't know what late manuals say, but the story on the 56 45 we had on the farm where I worked as a kid was that it had 20 weight engine oil in the transmission as the dealer said it was a "factory fox" for a properly adjusted but slipping hand clutch. Mostly you hear of using gear oil here. I would think the "tractor lubes" would work too and are thinner. A thinner oil will allow the hand clutch to release better so it is possible to shift more without using the engine clutch. Used to do this all the time once the oil was warm. Used the hand clutch most of the time, including loading manure into the spreader.
Brian G. NY
11-28-2003 15:32:12
Nate, You're referring to the hydraulics; 20W non-detergent.
