Allis Chalmers model B rear wheel bearing noise
Mike Montgomery
11-27-2003 04:18:11
Grinding noise on right rear wheel area. Old Model B given to me. Runs good but need to fix problem to use and eventually restore. Have a manuel but not very specefic and can not find parts, bearings, ring gears, seals, shims, Etc. Any advice or help would be apreciated.
steve
11-27-2003 07:28:12
 Re: Allis Chalmers model B rear wheel bearing nois in reply to Mike Montgomery, 11-27-2003 04:18:11
you can buy seals and bearings thru a bearing supply house like Motion Industries, or maybe order thru NAPA. Look in the phone book. Gears and shafts will have to be found by looking at the local used parts yard or tracotr grave yard. Tell us where you are located and you will get a couple locals numbers. ---Jack up one wheel 2 inches off the ground. put tractor in neutral and rotate wheel (other on the ground). does it tick once per revolution or does it grind constantly. constant is bearing, once per revolution is the bull gear tooth. about 4 times per revolution is the pinion gear. Try to wiggile the wheel to the center and back, does the hub move on the shaft?. Take the small oil pan off the bottom of the final drive (tucked in the wheel rim). It has 10 bolts about 3/8 diameter. There should be 2 quarts of gear lube inside. I bet it looks like tar and is 50 years old. They never got changed.
