WD45 wide front end controversy !!!!!
Dennis
11-26-2003 17:19:14
I have been casually looking for a wide front end for my WD45. Most adds I see are for a front end that fits WD,WD45, WD45Diesel. I have been told by various local farmers that the WD wide front won't fit on a WD45. What's the real truth. I don't want to spend the money on something that won't fit. Thanks, Dennis.
Little Ed
11-27-2003 03:15:35
 Re: WD45 wide front end controversy !!!!! in reply to Dennis, 11-26-2003 17:19:14
Does anyone (Schwartz?) still make an atermarket wide front end to fit any of these? Thanks
David
11-26-2003 18:18:14
The WD and early WD45s are exactly the same with a 3 bolt front pivot plate. The later WD45s have a 4 bolt pivot plate since the 3 bolt plate was prone to tear the bolt out of the casting with rough use. They are all interchangeable as a whole assembly.
wdTom
11-26-2003 18:48:29
 Re: Re: WD45 wide front end controversy !!!!! in reply to David, 11-26-2003 18:18:14
David is right,but I will add a bit. Wide front ends can also be put in WCs. Late 45 steering boxes have a bolt on flange on the bottom allowing you to bolt on a narrow, single, or steering arm for a wide front end. If it is a WC, WD, or 45 any front end from any of them will fit and work.
JMS/MN
11-26-2003 21:49:24
 Re: Re: Re: WD45 wide front end controversy !!!!! in reply to wdTom, 11-26-2003 18:48:29
Ditto- the wide front fits because the frame width is the same. Doesn't matter if it is a three or four bolt front end- that is on the pedestal----- --frame it fints into is the same, even if it is not original with the WC.
Brian G. NY
11-27-2003 09:35:25
 Re: Re: Re: Re: WD45 wide front end controversy !! in reply to JMS/MN, 11-26-2003 21:49:24
The later 4-plate unit is better than the earlier 3 bolt plate unit. Either will fit, as long as you get all the original pieces, including the front pedestal that matches the plate. The tricycle pedestal won't work.
wdTom
11-27-2003 16:52:23
 Re: Re: Re: Re: Re: WD45 wide front end controvers in reply to Brian G. NY, 11-27-2003 09:35:25
The late steering boxes will work for different front ends that bolt on, as I stated above. I don't think there are many of them though, but my parts book shows all the parts.
Brian G. NY
11-27-2003 19:02:59
 Re: Re: Re: Re: Re: Re: WD45 wide front end contro in reply to wdTom, 11-27-2003 16:52:23
The way I read the parts manual, the "front support" for the WFE is the same as that for the single wheel FE. There is a "dual wheel" (tricycle) support ass'y (pedestal) that was available to convert an existing WFE tractor to NFE without replacing the "front support". I've never seen one of these babys; I assume they are rare as "hens teeth".
JMS/MN
11-27-2003 14:42:24
Saying pedestal was a poor choice of words on my part. Technically I guess pedestal would refer to only the narrow front end. Steering box is probably what the big chunk of cast is called.
