Jim, Steve at B&B is right, there's more to this jump starting bit than it used to be. Plus, it's really always been dangerous and folks have gotten burned and hurt doing it. But we so often just don't think about things or take them for granted and go on. That said, we all know it's done, and I've done it many times myself. And I've jump started plenty of 6 volt system with 12 volts and gotten away with it. But like in a lot of things, moderation is the key. Don't connect the terminals until you're ready to start it. Connect it correctly and carefully, start it quickly then unhook it right then. You should be through in a few seconds. I've seen folks get one started then leave it connected for whatever reason and that's when the 12 volts starts to work on a 6 volt system. We watched a self propelled combine do that trick one day. The smoke started back at the engine then just worked its way right on up to the front where the controls were. Not a pretty sight. Some think that Allis-Chalmers was weird making their system a positive ground, but where it might be somewhat unusual, it's not so much so. There were Studebakers (of course they were weird too!), Chryslers, De Sotos, Dodges, Fords, Hudsons, Henry J's, Kaisers, Lincolns, Mercurys, Nash and Plymouth to name a few. Not all of those were positive ground, but many were. The theory of an electrical system does in some measures support grounding the positive. But it didn't catch on so hot, did it? God Bless and good luck.
