E gleaner engine
David (IA)
11-25-2003 11:27:51
Looking to confirm some information I was told. Does the Gleaner "E" combine have the same type 226 cid engine that was used with the WD45 and D17?
Thanks for your help.
David (IA)
12-17-2003 10:53:44
 Re: E gleaner engine in reply to David (IA), 11-25-2003 11:27:51
I would like to THANK all those who have been a great help with all my questions.
Thank you all.
Happy Holidays.
kenny
12-17-2003 04:24:42
the e engine will also work in the wd and wd45's
but you will have to rework the oil lines by the steering and the block doesnt match perfect but it will bolt up Ive done it many times the combine engines dont have near the hours a 60 year old tractor engine has and more power
Larry
11-26-2003 02:26:42
It will work in a D17, I've been told, don't know for absolute sure, that the combine engine has a longer stroke and a bit more power. I put one in a D17 last summer. You'll have to make some changes, the governor, like the one guy said, cover up the hole for the fuel pump, and the front pulley is different. If it were me, and I had the tractor engine, I'd change the whole front cover. If your D17 has power steering, and you don't use the tractors front cover, you'll have a dowel pin you'll have to pull out of the power steering pump, and you'll have to knock out the plug and put the tractors throttle linkage on the combine engine. I had mine pretty much together before I realized this, so I went ahead and used the front cover from the combine, it would have just been easier to swap the front covers I think. The flywheels are different, so you'll need the tractor flywheel. The exhaust is also different on the combine, and I used the original tractors intake/exhaust. Can't think of anything else I had to do, all it all it worked out great, and sure made a sweet tractor. I put in new studs for the intake/exhaust, new front and rear seals, pan and valve cover gaskets, and pilot bearing, and clutch disc, all together it ran about 320 dollars, not counting the 125 dollars I gave for the combine. I did pull a rod and main bearning and checked for wear while I had the pan off, mine were is great shape so didn't have to do anything there. There is a bushing you'll have to change for the throttle linkage to, if you use the combines front cover, about forgot that, can't think of anything else. Good Luck, holler if you need help, I don't know much more than what I've said, this is the first and only one I've ever messed with, but I'd sure do it again, I really like my D17.
legn4
11-25-2003 16:35:08
Yes, but the governor is a bit different. also the E uses a fuel pump that the 17 & WD(45) doesn't require. I put 1 in a D17 . Wish I had a few more. Eddie
den/southern illinois
11-25-2003 16:46:01
 Re: Re: E gleaner engine in reply to legn4, 11-25-2003 16:35:08
If you are looking of a Gleaner E motor...I have a buddy that has a good one...runs good and does not smoke. Its in Southern Illinois. E-mail me if you're interested.
Roger Fletcher
11-26-2003 11:37:01
 Re: Re: Re: E gleaner engine in reply to den/southern illinois, 11-25-2003 16:46:01
I am interested in this motor. I cannot E-mail you directly because your address is blocked. my phone is 319-498-4488 or e-mail at [email protected]
Roger
John bezemek
11-25-2003 17:14:37
I have a D17 in need of a engine den/southern illinois, if you get this please email me thanks John
FordTractorMan
11-25-2003 11:52:51
That is correct. Used to have 2 of those fine old machines.
