Sorry ... Paint Questions Again
Mark F
11-25-2003 11:05:34
I am still confused about the Persian 1 or 2 codes. I went to Ditzler and started to buy the PPG code for Persian 1, however the chip looked very orange/red. As I recall the Persian orange one is correct for a 1948 G tractor. It appears that there is much discussion here .. Does anyone really know the correct code for the more yellow/orange that was original in the late 1940s?.. Sorry to bring this up again, thanks for the help..Mark
JS in IL
11-27-2003 09:38:28
 Re: Sorry ... Paint Questions Again in reply to Mark F, 11-25-2003 11:05:34
hello, I recently painted my wd45 with a single stage ppg omni urathane. It looks great, fairly easy to apply and very tough. I had 99% of the tractor apart and took a section of original paint (still glossy) that was in between the radiator and the shroud, Also the replacement battery box from AGCO is very very very close to the correct color. I had my paint supplier scan each one to make an exact match and they came out so close it really didnt matter. Looks great, not to red, kind of a pumpkin orange but not quite.
Make sure to wear a respirator when spraying this stuff!!!!! !!
Rod (NH)
11-25-2003 13:40:38
Hi Mark,
Here's a visual sample of the two PPG persian oranges. You want the 60080 one. I cannot get it mixed in Delstar (DAR) in my area anymore. That line from PPG has been discontinued, at least by the dealers near me. It is available in PPG's more economical OMNI line as MAE 60080 for acrylic enamel, MTK 60080 for acrylic urethane and MBC 60080 for the bc/cc system.
third party image Rod
Dave K
11-25-2003 11:59:56
If it looked too orange it was probably PO # 2 which had a lot more red in it. For a 1948 you want PO #1 and the correct PPG code is Ditzler DAR 60080. An automotive PPG dealer can mix it for you. It is exactly correct and is what we used to call the "Pumpkin Orange".
Dave
