Squeeking sound from turbo?
Haig Stephens
11-25-2003 09:04:01
With our first Allis turbo-diesel, we are getting a squeeking sound when the engine speed ramps up. I know the whistling is from the turbo...but is a slight squeeking sound from it also?...is it a sign (sound) of a problem or???
Thanks in advance!
Bob/Ont
11-25-2003 15:03:47
 Re: Squeeking sound from turbo? in reply to Haig Stephens, 11-25-2003 09:04:01
Haig, take the intake pipe off and check the bearings by shaking the turb shaft. If you hear a squeeking sound the turbine or impeller is hitting the housing. Get it rebuilt before it dumps its cookies into the engine.
Later Bob
Pon
11-25-2003 09:08:46
I do remember the whistling, but not squeeking as such. One thing though, nobody's turbo will squeek long the way they turn. If you're really hearing a squeek just be sure you're getting oil to it. After that, it's about all you can do to one except go ahead and service or repair. God Bless.
FordTractorMan
11-25-2003 10:17:19
 Re: Re: Squeeking sound from turbo? in reply to Pon, 11-25-2003 09:08:46
Just to eliminate one possibility, check the hose that connects the cold air side of the turbo to the intake manifold. If it's blowing out air there, it'll make an odd sound.
FordTractorMan
11-25-2003 10:24:33
 Re: Re: Re: Squeeking sound from turbo? in reply to FordTractorMan, 11-25-2003 10:17:19
Whew. Ok, disregard the post about sucking air on the cold side of the turbo. Meant to say blowing it out. Must be the cold drugs & old age talkin...
FordTractorMan
11-25-2003 10:16:52
Just to eliminate one possibility, check the hose that connects the cold air side of the turbo to the intake manifold. If it's sucking air there, it'll make an odd sound.
