WD 45 or WD (?) wanted
SteveW/swMI
04-26-1998 17:41:11
Excuse the AC ignorance. Kid brother wants a WD45. Have found a decent WD (not WD 45). What's the difference? A rig available close to southwest Michigan would be nice. If the WD is close to a WD45, I'd appreciate information.
Larry
04-27-1998 13:06:55
 Re: WD 45 or WD (?) wanted in reply to SteveW/swMI, 04-26-1998 17:41:11
: Excuse the AC ignorance. Kid brother wants a WD45. Have found a decent WD (not WD 45). What's the difference? A rig available close to southwest Michigan would be nice. If the WD is close to a WD45, I'd appreciate information.
In short the WD-45 has quite a bit more power. The engine was bored and/or stroked to give more cubic inches.
In addition I believe all '45s had the snap coupler and traction control system. Only the late model W-D's had snap coupler.
My dad had both models, if your brother is planning any heavy filed work (plowing and disking) definitely go for the '45. If it's typical puttering around on his 5 acres (mowing, blading, SMALL baler) the WD will do just fine (at least in my opinion).
Larry
Dan D.
04-29-1998 10:58:32
 Re: Re: WD 45 or WD (?) wanted in reply to Larry, 04-27-1998 13:06:55
: : : Excuse the AC ignorance. Kid brother wants a WD45. Have found a decent WD (not WD 45). What's the difference? A rig available close to southwest Michigan would be nice. If the WD is close to a WD45, I'd appreciate information.
: In short the WD-45 has quite a bit more power. The engine was bored and/or stroked to give more cubic inches.
: In addition I believe all '45s had the snap coupler and traction control system. Only the late model W-D's had snap coupler.
: My dad had both models, if your brother is planning any heavy filed work (plowing and disking) definitely go for the '45. If it's typical puttering around on his 5 acres (mowing, blading, SMALL baler) the WD will do just fine (at least in my opinion).
: Larry
Most of what Larry wrote is partly correct. The 45 is newer, replacing the WD in 1953. The engine has 1/2 inch longer stroke (4 x 4.5 as opposed to 4 x 4 to give 226 cid instead of 201). All WD's have the traction booster system along with the 45's while only newer WD -45's came factory equipped with the snap coupler...most WD's and early 45's had it added on later to be exactly like the newer 45's.
