AC-C How good a tractor? Worth the money?
Mark
11-22-2003 09:03:14
I am looking for a good little tractor to mow with. I can buy locally an Allis-Chalmers C, WFE, PTO and mower for $1200. Decent tires, paint and runs real good. What do you think? Thanks.
Greg Ballantyne
11-24-2003 07:23:40
 Re: AC-C How good a tractor? Worth the money? in reply to Mark, 11-22-2003 09:03:14
Price depends some on where you are. Here in Md.that is a very good price, could easily sell for twice that. Same for the CA. I would look at the wide front, last several C or CA's I went to look at with wide fronts were B tractors from the torque tube forward.
Pat
11-22-2003 17:54:14
C is as indestructible as the B ,only more powerful.
Rick
11-22-2003 12:43:01
Mark, The C Allis with a mower is a good little mowing tractor. If it runs as good as you say and looks good too,then for 1200.00 I would jump right on it,because around here in central MO. that's a real good price,especially with the wide front end! They range anywhere from 1500.00 - 2500.00 here. Hope this helps. Rick
Dancingdog
11-22-2003 17:18:17
 Re: Re: AC-C How good a tractor? Worth the money? in reply to Rick, 11-22-2003 12:43:01
Rick, I can buy a wide front CA for $1100, three point and runs good, paint is weak. Is the CA more desirable than the C?
Rick
11-22-2003 17:51:18
 Re: Re: Re: AC-C How good a tractor? Worth the mon in reply to Dancingdog, 11-22-2003 17:18:17
Dancingdog, Yes,the CA is a more desirable tractor normally than the C Allis,since it has the 4 speed tranny,hand clutch and also the power adjust rims,just to name a few things. If you can get one picked up for 1100.00,I'd say you'd better go and get it! Especially if it's got the wide front end and three point on it already and runs real good. Rick
old
11-22-2003 11:44:06
Sounds a little high,but if the tires are very good it is probably worth it
steve
11-22-2003 13:09:56
 Re: Re: AC-C How good a tractor? Worth the money? in reply to old, 11-22-2003 11:44:06
tractor worth $800- $1200, mower if good is $500 minimum. buy it now. would be $1500-$1800 in Illinois, minimum.
Mark
11-22-2003 14:00:31
 Re: Re: Re: AC-C How good a tractor? Worth the mon in reply to steve, 11-22-2003 13:09:56
Thanks to all that gave their advice.
