converting a gas wd45 to a diesel
trevor
11-19-2003 16:46:28
Wanting to build a diesel 45 can you put one in a gas chasis? if so what do you have to change. one more possible problem wanting to put in a 262 out of a d17 or 19 any help would be great
Anon
11-20-2003 16:48:55
 Re: converting a gas wd45 to a diesel in reply to trevor, 11-19-2003 16:46:28
Well let's see: yes you could use a 262 and possibly a 276 Buda. You would need the diesel radiator,throttle linkage, starter,generator, fuel tank,battery box,wiring harness... you know it would be cheaper and easier to just find a diesel one with a bad engine.
Joe
12-14-2003 18:27:04
 Re: Re: converting a gas wd45 to a diesel in reply to Anon, 11-20-2003 16:48:55
What is a 276 Buda? I am familiar with a 262 but am not aware of the 276. What were these engines used in? Thanks
trevor
11-20-2003 18:23:24
what tractor did the buda engine come in? so far finding a diesel chasis is almost impossible where I am located the ones you do find are so high that you can buy a decent d17. Also what kind of hp. does the buda engine have? an can you tell the difference in the 262
