That pesky throttle spring
Rich, NJ
11-18-2003 05:06:52
Did early Bs (38) have that throttle rod spring? Mine does not have the hole in the rod to accept it. Was another method used to stabilise the throttle and RPM? Just about everything else is different on a 38.
Thanks, Rich
Tyler(WA)
11-19-2003 16:45:49
 Re: That pesky throttle spring in reply to Rich, NJ, 11-18-2003 05:06:52
My '38 does not have the hole for the spring but it sure will hunt if I don't have a spring.
I use the spring in place of the cotter pin at the carberator linkage and go from there to the manifold stud with the spring.
Rich,NJ
11-20-2003 05:30:00
 Re: Re: That pesky throttle spring in reply to Tyler(WA), 11-19-2003 16:45:49
Now where do I get one? I've heard they're tricky to make. What is the dia of the wire? What is the dia. of the coil? How strong is it? Thanks in advance! Rich
alan nj
11-18-2003 13:08:00
rich - my 38 also does not have spring. i've been told the early ones did not. where in nj are you??
