Were is The serial number on a WD
Westley Albrigh
04-25-1998 17:58:16
Were is the serial number located on a WD and also were is it located on a WD-45.
Ted Buisker
04-25-1998 18:28:42
 Re: Were is The serial number on a WD in reply to Westley Albright, 04-25-1998 17:58:16
: Were is the serial number located on a WD and also were is it located on a WD-45.
The serial no. for both the WD and WD-45 is located on the left side of the rear end housing, just below the hole for the brake spring. If you have a very early model WD it may be stamped on top of the rear end just to the right of the brake adjustment cover. Good luck. ^TED
