Shifter Flop/Slop
Ron P in TN
11-17-2003 13:30:38
I have a 53 WD with helical(curved Shifter). Most times careful use produces good shift.@ times it hangs in R or 2nd. Have been told shifter is worn out. Is it fact? where do I get one or dimensions of weld-up/grind down repair. Need Help just a beginner.
wdTom
11-17-2003 18:10:20
 Re: Shifter Flop/Slop in reply to Ron P in TN, 11-17-2003 13:30:38
You may be able to remove the lever and weld or braze the bottom back into shape enough to make it work. To remove, remove the boot and a snap ring, then pull up. don't loose the dey on each side that keeps the shift lever from twisting in it's ball and socket. These are free to fall into the transmission when the shiftlever out. See my post on the WC shifter a few days ago. That may help too although yours is a different problem.
