WD Governor / RPM Problem
S-Wess MO
11-17-2003 13:13:38
I am pulling a WD with a Gleaner E Governor. The problem I am having has 2 parts.
1. How do you hold the RPMs to the allowed 1892 RPMs
2. I am using a stop block on the throtle arm and it only allows me to pull the throtle down about 2-3 inches and takes a few seconds to get the to top end and when I hook to the sled it seems that the governor will not keep the rpms up and I go down the track at about 1100 RPMs and I can't get any more RPMs
Should I rebuild my Governor?
Do you use the stock Governor spring or somthing else?
What can I do?
Thanks for your help
S-Wess
Dave K (FL)
11-18-2003 14:49:43
 Re: WD Governor / RPM Problem in reply to S-Wess MO, 11-17-2003 13:13:38
Use the standard governer that came with the tractor. The combine gvr will not give you a range of speeds, it simply tries to keep a constant speed.
Dave
Kent of SW MO
11-18-2003 07:06:35
Combind govenor an not the same as a tractor govenor. Combind engines are set run at one speed. Tractors need to run at various speeds.
