Collant leak A/C B
Ken Boyles (WI)
11-15-2003 15:52:15
I have posted here B4 re: sleeve installation. Anyway, after replacing sleeve seals because of collant leaking into oil, I experienced severe collant leaking into #3 combustion chamber w/ engine at rest & filled w/collant. After much testing and head scratchin, I found that the #3 sleeve has a creak ~ 2" long around the top about at the height of the lip. Now after the fact, It seams that it should have been easier to find. I used powered chalk blown into the combubtion chamber w/ compressed air to trace the leak. Any way, I had searched the forum for ideas to solve this & did not see this problem specifically. So that is why I am sending this post. Friends, it's FYI. KB
Dick L
11-16-2003 08:09:07
 Re: Collant leak A/C B in reply to Ken Boyles (WI), 11-15-2003 15:52:15
If you are saying that the sleeve its self is cracked thhere is only one fix and that is to replace it. If you asking what caused it I would say it would be a pretty good guess that water got into the sleeve and it froze. If it was rusted fast and some one tried to drive the piston down with a big hammer you could cause this as well. It would not happen under normal use.
