well I agree with Ron, the oil bath is pretty darned effective at doing its job, and you already have it. However, my wd45 sits in the shop nearly all its life looking pretty and only does snow removal duty and a few odd jobs here and there. I removed the oil bath stuff becuase it had rotted to oblivion and I wanted something ummmmm sportier. Go grab a $15.00 universal cone filter for the sport import rice burning crowd from Autozone. (While you are there get a 2" hunk of straight radiator hose and two new clamps) The filters have an anodized finish and slip over a 3" pipe. Then grab your Summit racing catalog and order up a 2" mandrel bent hunk of exhaust tubing with a 6" radius 180 bend in it. cut the pipe in the middle of the bend for a 90 deal. Also order a 2 into 2 1/2" exhaust reducer. Snag a piece of 1/8 or 3/16" thick 4" piece of flat steel. Now drill four bolt holes in the 4" plate to bolt up to the spot where your oil bath used to go, smooth the corners out to make it look pretty then weld the reducer to the long end of the tubing to "neck it up" to 2 1/2"s The filter will snug down the 1/2" to make it really snug on the reducer and pop out of the hood where the original breather cap was. The only hard part is welding some scrap stock from the bolted plate to the tubing to space it out straight up and down and keep the whole deal from wiggling. Clamp up the radiator hose once you have it cut to size and slipped over the tube and the carb neck and you are done except for a coat of paint. This keeps your air filter above the hood for a cleaner batch of air, no ripping the filter off either. It also allows the stock fuel line and lights to fit no interference with anything. You can get a foam pre-cleaner for the filter if really in dusty conditions, and since you can see the paper element and it takes $15.00 and about 60 seconds to replace it, it kind of makes you feel obligated to change it out every once in a while. If you really want to be a conversation piece paint it AC orange then rub on some of the black transfer lettering on it (get it at the arts/crap section of Wal-Mart) with a really obscure AC like part#----- IE AC-4112-SD with Experimental or severe duty in smaller letters under the # Then swear on everything holy that it is a very rare Severe duty air filter setup used in desert applications, or for the moon or something you get the idea. Tell em the filter is no longer made so you had to improvise, but the dry air intake is the real deal and see them run to the parts books!!!! I have pics of my setup if you need help.
