WD-45 Engines
Otis
11-13-2003 12:35:13
Are there two different motors in a 45, if so how do you tell the difference? THANKS
Otis
11-14-2003 08:51:56
 Re: WD-45 Engines in reply to Otis, 11-13-2003 12:35:13
My question was about gas motors, the guy at the parts house said there was two gas motors for a WD45. He could have been confused.
steve
11-14-2003 15:12:48
 Re: Re: WD-45 Engines in reply to Otis, 11-14-2003 08:51:56
as John said there were changes to the basic engine used in the WC- WD- WD45 then the D17 as time progressed. YOu give him the serial number and there should be no problem. Is possible to find a WC with a D17 engine, and maybe vice versa, but i would doubt it. Go by serial numbers.
Kurt : Ky
11-13-2003 15:34:28
226 gas and i believe a 230 diesel. i know it had a diesel option not quite sure on the cubic inch.
Bob
11-13-2003 17:11:59
 Re: Re: WD-45 Engines in reply to Kurt : Ky, 11-13-2003 15:34:28
The diesel engine was the Buda 6B230. The same engine that was used in the Cockshutt 40.
Dave Wi.
11-13-2003 15:30:21
yep,one gas and one deisel,gas 4 cyl.,deisel 6 cyl.
Bryan Smith
11-14-2003 12:32:37
 Re: Re: WD-45 Engines in reply to John (C-IL), 11-13-2003 13:49:03
Now let me add fuel to the fire - weren't there "GA" and "PA" serial number suffixes on WD-45 motors? Or not? I know there were two different suffixes on WD motors (201 CI), one was supposed to be a 5.5:1 compression ratio and the other was a 5.75:1 compression ratio, both were gasoline models (not a tractor fuel version - the compression on it was around 4.75:1, right?). OK< fire away ....!
John (C-IL)
11-14-2003 16:51:25
 Re: Re: Re: WD-45 Engines in reply to Bryan Smith, 11-14-2003 12:32:37
Bryan, Correct you are oh observant one. My owners manual says 2 different compression configurations. 6.5:1 (gasoline) and 4.75:1 (Low Octane fuel). There is also a picture of the 2 different manifolds. But as far as the mechanicals the engines are the same with the noted exception of the pistons and the manifolds.
Brian G. NY
11-14-2003 18:18:26
 Re: Re: Re: Re: WD-45 Engines in reply to John (C-IL), 11-14-2003 16:51:25
The WD engine suffixes were "KA" low compression and "PA" high compression while The WD-45 suffixes were "K" low compression and "G" high compression. The K & KA quite obviously stand for Kerosene (tractor fuel) and the G fits Gasoline quite nicely. What the PA stands for, I never quite understood.
Dave Wi.
11-15-2003 05:14:19
 Re: Re: Re: Re: Re: WD-45 Engines in reply to Brian G. NY, 11-14-2003 18:18:26
Maybe propane?
Bryan Smith
11-17-2003 07:03:19
 Re: Re: Re: Re: Re: Re: WD-45 Engines in reply to Dave Wi., 11-15-2003 05:14:19
Here's something Ed sent me some time back - see if it follows along (for a WD) with what you guys know:
"Original gas motor for WD had GA suffix and was 5.5:1 compression (yes that low - that was before they had decent octane); In mid-1951 as I recall - at motor s/n 283022, they changed to the PA suffix which was 5.7:1. The K or KA suffix as I recall was in the high 4's say 4.7:1 maybe to burn distillate (kerosene) fuel."
Ed's done a lot of work on this kind of stuff and knows his numbers - he tries to keep a running track of engine serial numbers vs tractor serial numbers (some curves of his work on my website - link below). I doubt that a 226 ci gasoline WD45 engine had two different compression ratios, but it looks like the 201 ci gasoline WD engine did. Hmmm .....
