WD or WD45?
Jim Pass
11-12-2003 21:45:05
I have just discovered old tractors in the last couple of years. I've just bought my first WD, or is it a WD 45? I haven't found the serial number. Is there a quick, simple way to tell the difference ?
Thanks!
Jim
Mike
11-30-2003 05:32:38
 Re: WD or WD45? in reply to Jim Pass, 11-12-2003 21:45:05
WDs prior to 1953 used the sliding gear transmission with a straight shiftlever. In 1953 the tranny was changed to a constantmesh trassmission that had a curved shiftlever. WD production stopped in 1953 and production resumed with the WD45 which also used the new transmission with the curved shift lever. The new transmission had a faster reverse and if abused could jump out of gear. Our WD with the straight shift lever still works good and does not jump out of gear. Our WD45 transmission on the other hand, was so bad we couldn't used some gears, so replaced every thing from the transmission back with the rear end of a WD parts tractor and now works like new again. I don't mean to scare anyone out of buying a WD45, ours was just so bad because it had a lot of gear grinding. If the owner did not abuse the tractor like we did it will probably be just fine.
Bill IN
11-13-2003 02:55:10
The serial number is on the top left side of the rear end housing. When you're standing behind the tractor look at the verticle surface just below the left brake cover. It should be looking at you. If the number is smaller than WD 146607, it's a WD, Higher is a WD 45. If there is a flat steel plate bolted to the block behind the distributer, the engine is a WD. With rare exceptions, 45's have a curved shifter handle.
Bryan Smith
11-14-2003 12:35:11
 Re: Re: WD or WD45? in reply to Bill IN, 11-13-2003 02:55:10
Picture of the serial number at my website (link below).
