WD-45 starting problem
Don ( In.)
11-12-2003 20:19:07
Have new battery (6 volt),new ground strap, new points,condensor,plugs, starter rebuilt, turns over good but won't start. Pull it 5 ft. or less, it starts and runs like new. By the way, it was restored to new condition about 3 years ago, by someone else. It has had limited use in three years. It seems to have weak fire at points.
old
11-13-2003 05:42:51
 Re: WD-45 starting problem in reply to Don ( In.), 11-12-2003 20:19:07
You might try a new coil, and check you dist. cap. Theres an easy way to check a dist. cap spray the inside with starting fluid and let is dry for a moment and if its cracked any where you will see lines in it. hope this helps
bw in mo
11-16-2003 05:07:05
 Re: Re: WD-45 starting problem in reply to old, 11-13-2003 05:42:51
Maybe some one put a resister in the hot line to coil from a previous 12 volt. Weak fire can be from weak coil - cond. - corroded points, or not gaped correct.
Good luck B W
