AC B Wiring
Jon
11-11-2003 14:23:18
Can someone tell me how the the battery cable and other wiring are routed around the right side of the engine to get to the starter and then over to the left side to the generator. Are there clips to hold the wires or do they just "hang" there after they come out from or from under the battery box. A picture or diagram would be helplful.
Thanks.
Dick L
11-11-2003 15:29:14
 Re: AC B Wiring in reply to Jon, 11-11-2003 14:23:18
The battery cable that goes to the starter comes out the top of the battery box and into the toolbox/tank support. To comes out to the starter thru a hole for that close to and back of the starter. The wiring harness comes out of the bottom of the switch/fuse box and runs under the battery box thru the toolbox/tank support with the power wire for the switch box going out the same hole the starter battery cable. Both fastens to the starter stud. The harness them runs down the left side of the tractor with the charging wires for the generator cutout and feild being hooked at that point. The light power wire them kooks to a terminal on the fan hjousing. The mag wire runs under the themostat housing thru a clip under a bolt at the bottom front of that housing.
There is harness clips on the left side but I would have to look to tell where they go at this moment.
