AC CA spin out hubs
Old Tractor Guy
11-11-2003 07:55:12
I recently bought a 1952 CA, when I picked it up I noticed someone had welded the spin out hubs and cut off the cam knob on each hub. I'm going to try to clean off the welding and see if I can save them, but it looks doubtful at this point. I'll replace the rims, but does anyone carry these hubs? I'll probably need the adjustment stops for the rims, too. Any help would be appreciated.
OTG
Ted from Maine -problem w
11-13-2003 15:02:30
 Re: AC CA spin out hubs in reply to Old Tractor Guy, 11-11-2003 07:55:12
When moving along in my CA, my left side power rim makes a snapping sound. I can't see where the rim is moving when I inspect the rim areas, but something is certainly happening. The rim does not snap each time it turns but snaps once about every minute or so.Appreciate your help, and thanks in advance
Sid
11-15-2003 19:44:09
 Re: Re: AC CA spin out hubs in reply to Ted from Maine -problem w, 11-13-2003 15:02:30
You mentioned checking the rim area and finding nothing have you checked the lugs on the center of wheel. If they are just a little bit loose they will do that.
Eldon (WA)
11-11-2003 08:31:36
I've got 2 extras that almost look like new for sale.
Old Tractor Guy
11-12-2003 07:29:07
 Re: Re: AC CA spin out hubs in reply to Eldon (WA), 11-11-2003 08:31:36
Thanks for the reply. This weekend I'll see if I can get the welds loose, and let you know. I appreciate the fast response.
OTG
