What type WD pedestal oil?
Randy Graf
11-10-2003 14:05:36
Does anyone know what type of oil and how much goes in the pedestal of a WD? I can't seem to find the info anywhere. Thanks for your help!!!!! !!
Dave K
11-11-2003 07:00:14
 Re: What type WD pedestal oil? in reply to Randy Graf, 11-10-2003 14:05:36
To answer the other part of your question, the manual says to add enough lube to cover the bottom of the worm. As the worm turns it picks up the lube for the gears. I use 140 wt in mine.
Dave
Sid
11-10-2003 18:10:34
The manual says SAE 140 gear lubricant wide front axle and single front wheel SAE 250.
Ron
11-10-2003 16:39:28
I use 140 wt in mine, and since it leaks some, I add some grease, too..!!! 90 wt was probably called for, but the 140 wt works real good, and doesent leak as fast..!! 140 wt will get a little "stiffer" in cold weather, tho, but not bad..!
