WD rearends
Willie
11-08-2003 14:36:18
How do I tell if a WD has a castiron or steel rearend housing? I've heard that the steel is lighter. New to Allis, Thanks
John (C-IL)
11-08-2003 15:15:33
 Re: WD rearends in reply to Willie, 11-08-2003 14:36:18
WDs are all the same. Now if you are talking WCs, that's a different animal, and pretty easy to tell. If the serial number is on a square pad in the middle of the diff. housing it is cast.
Willie
11-08-2003 17:39:40
 Re: Re: WD rearends in reply to John (C-IL), 11-08-2003 15:15:33
Whats the diff between the wd and wc rearends?
JMS/MN
11-10-2003 17:37:38
 Re: Re: Re: WD rearends in reply to Willie, 11-08-2003 17:39:40
WD rear ends are multiple cast parts bolted together. WC cast rear ends are one piece from one side to the other. Does not have a rear cover bolted on. WC steel rear ends were produced for a short time during WWII.
wdTom
11-08-2003 18:43:53
The WC looks like a truck rear end, the WD is a special casting that doesn't look like a typical rear end casting, And it is supposed to be stronger than the WC.
Willie
11-08-2003 18:46:53
 Re: Re: Re: Re: WD rearends in reply to wdTom, 11-08-2003 18:43:53
Are WD and WD45 the same?
John (C-IL)
11-09-2003 04:45:27
 Re: Re: Re: Re: Re: WD rearends in reply to Willie, 11-08-2003 18:46:53
No, the WD has straight cut gears and the WD45 has helicut gears. They have the same outward appearance, the serial numbers are sequential and the 45 has the curves shifter which is also on the late WDs.
wdTom
11-10-2003 18:43:53
 Re: Re: Re: Re: Re: Re: WD rearends in reply to John (C-IL), 11-09-2003 04:45:27
Aren't you refering to the transmissions? The rear ends are the same I thought. And some later WDs had the newer transmission with the curved shift lever.
