Ac Heads
Jerry M.- TN
11-07-2003 13:03:22
Will the WC, WD, and Wd-45 heads interchange?
Which would be better for pulling? Also,would flat-top pistons be better?
old
11-07-2003 13:39:48
 Re: Ac Heads in reply to Jerry M.- TN, 11-07-2003 13:03:22
The WC and WD heads will they are the same engine but I'm not sure about the WD45 its a bigger engine. hope this helps
wdTom
11-07-2003 17:40:58
 Re: Re: Ac Heads in reply to old, 11-07-2003 13:39:48
I think there are short and tall heads and that all will work on all engines. You will need short or tall head studs. About 1952 (I think) they went to a taller head to straighten out the passages a bit for better air flow. The 45 engine is the same basically. It has a 1/2" longer stroke and power crater pistons.
bw in mo
11-07-2003 19:27:03
 Re: Re: Re: Ac Heads in reply to wdTom, 11-07-2003 17:40:58
PS One thing more you will need the correct push rod's
bw in mo
11-07-2003 19:23:30
Some of the Wc have 12 bolt ,others have 15 bolts . All 15 bolt heads thick or thin will fit, if the bolts are the correct length.
doorguy
11-07-2003 20:30:21
 Re: Re: Re: Re: Ac Heads in reply to bw in mo, 11-07-2003 19:23:30
Did they change the location of the top hose water outlet from the left top side of the head to the front of the head? I have a head supposedly for a WD45 that is different in this respect. Thanks doorguy
bw in mo
11-08-2003 18:39:00
 Re: Re: Re: Re: Re: Ac Heads in reply to doorguy, 11-07-2003 20:30:21
They used the same style through the 170, the thermostat housing bolted on the left side of head & used flat plate on back hole.
