Positive Ground Alternator
JR in Indiana
11-07-2003 07:18:59
I have a Delco alternator mounted on an AC D-14 tractor. A previous owner has converted the alternator to positive ground. It has worked ok until recently when I replaced the bearings. It has only a battery wire-no signal or exciter hookup. These pins are there but not used. My question is: How should this be hooked up?
Are the signal and exciter pins really inactive?
If active, how should they be hooked up? Thanks much
Steve in N.J.
11-08-2003 19:30:21
 Re: Positive Ground Alternator in reply to JR in Indiana, 11-07-2003 07:18:59
JR,
As the other fellows mentioned, sounds like your tractor is equipped with a one wire alternator which at a certain RPM, (850-1400 depending on the enclosed regulator) the regulator excites and sets the alternator in the charging mode till you shut the engine off. This procedure starts all over again when the engine is re-started. We have Delco 10SI 1 & 2 wire Alternators in stock if ya need one. Drop us a line if interested..... ..
Steve/B&B Custom Circuits
[email protected]
steve
11-07-2003 18:38:45
there are various voltage regulators available for the delco alternator. some are 6 volt, some are 12 positive ground, but the most common is the 12 volt negative ground. the "odd balls" normally were single wire conversion type regulators. that being said, i would bet you left off a plastic washer during reassembly and have the regulator hot terminal grounded. you can disassemble and check, or like Doug said, i would take to Auto Zone and for $40 trade for a 12 volt neg ground rebuilt unit.
Doug in OR
11-07-2003 08:01:08
If this alternator has been modified, and it apparently has, all bets are off as to hookup. On an older Delco, the large stud is the battery terminal. Pin 1 is the exciter terminal. Pin 2 is the sense terminal. Pin 1 would normally need a voltage applied to it - at least until the alternator builds its own voltage. You cannot leave a voltage applied to this terminal when the engine is not running - this would run your battery down. Pin 2 can be wired right over to the battery stud.
Considering that it looks as though your alternator has been modified to a one-wire version, I would NOT make any changes. I would more likely suspect that you need to check your brushes and slip rings. They may be dirty or something mught have been knocked out of alignment.
If push come to shove, you can always convert to negative ground. It is a simple precedure. You can then use a conventional alternator.
