NEED ADVICE ON AC B
PETE
11-06-2003 16:09:38
LOOKING AT PAPER AND FOUND AN AC MODEL B FOR 300.00 BUT THE AD SAYS IT NEEDS #4 CYL. KIT. DID THESE TRACTORS HAVE SLEAVES OR WHAT? ALSO I DONT KNOW ANYTHING ABOUT THESE TRACTORS OTHER THAN JUDGING BY PICS THEY ARE SIMILAR TO FARMALL A'S OR CUB. WOULD LIKE TO HAVE A TRACTOR LIKE THESE, WOULD THE AC B FIT THIS OR WITH THE #4 CYL PROB SHOULD I JUST FORGET IT.THANKS FOR ANY FEED BACK
Steve in N.J.
11-08-2003 19:38:23
 Re: NEED ADVICE ON AC B in reply to PETE , 11-06-2003 16:09:38
Pete,
That's a good deal providing its all there. Sleeve kits are available for them. I have a B that I restored a few years ago, and put all four sleeve kits in so the engine was "fresh". Each sleeve kit comes with sleeve, rings, piston, o-rings & piston pin. We don't keep the kits in stock but can get them. The Model B is a fabulous little machine! Go for it!
Steve/B&B Custom Circuits
Jo-JO
11-07-2003 18:36:18
Buy It!
John P. Martine
11-06-2003 18:02:43
Personally, after paying a little more than your stating, and knowing what I had to put into my Allis B engine to get it where I have it now, I think $300 is a darn good price. I don't know how much of the work you may be able to do yourself, but to have someone else, say a machine shop overhaul it and you provide all necessary parts, your looking at putting little under or right at $1000 if you go ahead and do a full blown overhaul of the engine. Now, a single cylinder sleeve would most likely be considerably less. --JPM
old
11-06-2003 17:14:10
yes you can get sleeve kits for them. I know if I found something like that I'd buy it if of course I had the money hope this helps a little
wdTom
11-06-2003 18:03:14
 Re: Re: NEED ADVICE ON AC B in reply to old, 11-06-2003 17:14:10
If all it needs is one sleeve kit, you will have a deal. Even if you had to put more into it,these are good tractors, simple, rugged, reliable, and a lot of power.
